engine cut problem
engine cut problem
Postby mhd on Tue Oct 20, 2009 9:13 pm
Hi Every body
I have problem , the engine cut at 6800 , and setup the REV to 7800, befor the car was Ok but after I rebuilt the engine the problem appear, I tried all the mixture from 0.65 to 0.75 and igntion from 20 to 28 and boost from 0.6Bar to 1 Bar also the same
the engine keep cut at 6700 to 6800 RPM
any idea please
the car 2006 SUBARU STI 2.71L
Ps:in the attachment the Loged file
Thank's and best Regards
M.Olabi
20091020-1048002.ld
(97.4 KiB) Downloaded 1570 times
M.Olabi
ProRacing Co.
mhd
Re: engine cut problem
Postby mhd on Wed Oct 21, 2009 7:26 pm
Hi every body
Today I incress the boost to 1.2 Bar the engine now cut at 6500-6600 RPM less than 200RPM
Thank's
M.Olabi
ProRacing Co.
mhd
Postby stevieturbo on Fri Oct 23, 2009 3:37 am
Can you explain the cut better ?
Is it like a rev limit, missfire etc ?
Is the throttle staying open ?
Postby oah on Fri Nov 27, 2009 6:35 am
Dear
how much the spark plug gap....
Regards
oah
Postby forcefed1981 on Mon Nov 30, 2009 4:53 am
mhd wrote:Hi every body
Thank's
Sound like plug gaps or fuel delivery problem
forcefed1981
Postby mhd on Thu Dec 03, 2009 5:42 pm
it is was not spark gap, is was mixture problem , we think the engine was not mix the fuel and air well so the mixture go very rich so that the engine miss fire
and until now we don't know whay that happening, and now we trim a lot of fuel at high rpm
like for EX: in fuel table at 5000RPM we run 81 and in 7000RPM we run 51.
any idea please.
M.Olabi
ProRacing Co.
mhd
Postby SprinterTRD on Fri Dec 04, 2009 7:46 am
The lambda sensor is too close to the turbo outlet and is not reading the correct A/F ratio.
Return to M800 Plug-In ECUs
