How to open a "Start Files"
Tue Sep 29, 2009 7:47 am
by dzhingov
Hi everybody,
I want to open a "Start Files" for Mitsubishi EVO to see the fuel and ignition maps. How this can be done without conect the ECU to the program. Or if anybody can open "Mitsubishi EVO4-6 M800 OEM Start-up (no immobiliser)", please send me a pic to fuel and ignition maps.
Thank you.
Re: How to open a "Start Files"
Tue Sep 29, 2009 10:17 am
by RossB
You can do this with the ECU Manager program which can be downloaded from the web site
http://www.motec.com.au/software/latestreleases/. THe file you have probably has a file extention ot .e23, this means that you need to use M800 ECU Manager Version 2.3 to view it. A MoTeC start file is only intended to be used as a basic configuration to get the engine running and will not have fuel or timing maps that represent a properly tuned engine.
Mon Oct 19, 2009 8:00 am
by xpro
Hi, i also have the same issue, the maps i have are .e21 extension and i and i have both version of ecu manager v2.3 and v3.5 and unable to open. Any ideas please?
edited: just realised theres and old release section available to download v2.1
thanks
Mon Oct 19, 2009 8:12 am
by RossB
xpro, You can upgrade your 2.1 files to 2.3 or 3.5. If you are upgrading to 3.5 make sure you read the notes in the Read me file though.
