How to open a "Start Files"
Postby dzhingov on Tue Sep 29, 2009 7:47 am
Hi everybody,
I want to open a "Start Files" for Mitsubishi EVO to see the fuel and ignition maps. How this can be done without conect the ECU to the program. Or if anybody can open "Mitsubishi EVO4-6 M800 OEM Start-up (no immobiliser)", please send me a pic to fuel and ignition maps.
Thank you.
dzhingov
Re: How to open a "Start Files"
Postby RossB on Tue Sep 29, 2009 10:17 am
You can do this with the ECU Manager program which can be downloaded from the web site http://www.motec.com.au/software/latestreleases/. THe file you have probably has a file extention ot .e23, this means that you need to use M800 ECU Manager Version 2.3 to view it. A MoTeC start file is only intended to be used as a basic configuration to get the engine running and will not have fuel or timing maps that represent a properly tuned engine.
Postby xpro on Mon Oct 19, 2009 8:00 am
Hi, i also have the same issue, the maps i have are .e21 extension and i and i have both version of ecu manager v2.3 and v3.5 and unable to open. Any ideas please?
edited: just realised theres and old release section available to download v2.1
thanks
xpro
Postby RossB on Mon Oct 19, 2009 8:12 am
xpro, You can upgrade your 2.1 files to 2.3 or 3.5. If you are upgrading to 3.5 make sure you read the notes in the Read me file though.
Return to M800 Plug-In ECUs
