Subaru N14 and M800 WRX910
Postby Alex B on Wed Jul 08, 2009 7:04 am
Hi everybody,
When using M800 in the new Impreza the ABS, DCCD, VDC systems will not function.
Its all fine for a Gr N car, but not really acceptable for a street car. The ABS
and DCCD are important!
Does anyone know if there is any work around for this problem.
Perhaps some sort of CAN interpreter board or interface that
could exchange correct messages with these systems?
Quite a few projects are held back by this problem.
Regards
Alex
Alex B
Re: Subaru N14 and M800 WRX910
Postby husamsalem on Fri Oct 23, 2009 11:29 am
I have the same problem anyone can help please
Thanks,
Husam
husamsalem
Postby Alex B on Thu Oct 29, 2009 8:05 am
Just checking if there is any update on the newer cars' (GRB, R35) support?
Other guys have done it. There are plug & play ECUs already available,
fully CAN integrated and compatible with the above cars.
Or should we be waiting for the newer M1 ECU?
Best regards
Alex
Alex B
Postby Leo on Fri Feb 26, 2010 8:41 pm
Hello Alex.
I have done it.
I used 2 ways:
1-software
2-software+hardware.
First way is not fully correct and CAN compatible. Only MoTeC setup's used. The result is: SI-Drive and DCCD.
Second way is fully correct. All systems are working without mistakes, but 'Subaru Select Monitor' cannot see Engine ECU.
Leo
Return to M800 Plug-In ECUs
