2006 STI plug in M800 idle problem
Hi All,
FWIW, I'm following this one up for a good friend who is trying to help another 'good friend' with his 2006Sti and the M800 plug in. (i.e. not my problem just trying to help another MoTec buddie )
Situation is this;
Stock 2006 STI with the exception of larger fuel pump and turbo (un-molested long motor including injectors)
With factory ecu plugged in, idle Lambda = 1.0 and everything is happy
With M800, idle lambda is .78-80 (rich) - but when you try and trim it out on the fuel map it will drop a cylinder.
We have considered this;
Factory Ecu can control fuel pressure - M800 doesn't
Therefore at idle a higher fuel pressure with same injector duration means we have to compensate on the fuel map
Idle voltage and Injector dead time compensation - 13.8V and even then if we adjust it on the fuel map it shouldn't be a problem, why would it then drop a cylinder?
Wiring/Fuel system - all good with factory ECU, only an issue when plugging in the M800
Lambda measurements - Motec PLM
'Buddie's' have discussed with Ross with limited success (not having a go at you Ross, just asking for more suggestions or direction here because we are lost for ideas).
Many thanks
Cam
Situation is this;
Many thanks
Cam
