subaru 2008 crank ref setting ??
Hi guys
can you tel me the correct (crip) crank index position setting for a 2008 subaru JDM spec 2 ltr double vvt engine ?
as the 3 base maps i have are all diferent from 547 to 580 !! and the release notes give 2 diferent setings surely on a production engine there cannot be that much error !!! i know its best to check this on each engine but i need to know that im in the right area to start with,,
the base map i was supplied had 580 and the engine sounds very retarded and got very hot on the exhaust at idle
thanks guys
thanks guys
