How to connect E888 to M800 PnP
hi,
I like to buy E888, but I don't know how to connect it to M800 PnP.
I have a few questions about it.
1. Does it connect via communication or CAN cable? If yes, is the wire included or do I have to buy special wire loom for that?
2. I know that the output of E888 will not work with M800 PnP, but will the M800 be able to react with the inputs to the E888 say the oil pressure is dropping at high rpm, or the fuel pressure is not enough and can the M800 cut the rpm to avoid engine damage?
3. There are 8 thermocouple inputs to E888, do I need TCA or thermocouple amplifier if I put type K TC for EGT?
4. Is there any other wiring harness included with E888? I mean how would I connect sensor signals to it?
Thanks in advance
James
Thanks in advance
James
