Subaru WRX 7 board AV7 fuel level sensor
Hello nice people,
I have Motec M800 PNP WRX7 board on my car and want to use all possible channels from it to be transmitted to my C127 Dash. So my question is following:
On the WRX7 user manuals it's given that on B25 is AV7 which is fuel level sensor. After a talk with Motec Europe (Answer from Josh Bailey) I understood that AV7 is permanently wired with 5V pullup inside the board and cannot be changed to use for other input except stock fuel level. Unfortunately Motec told me that they don't have a calibration for it.
So in User Channel 1 I put AV7 input and I see that voltage reads values upon the fuel level in the tank. But in calibration menu I don't know what to choose (cannot find predefined, 1-to-1 or custom calibration appropriate for level)?
And can I kindly ask you how to transmit this User Channel 1 information via Can to the C127 Dash?
In Dash Communication Setup I have M800 Set 1 but not and this User 1 channel assigned to it?
Probably I must create Custom data set? Or to add channel in the same M800 Set 1? Can addresses and Data is really hard for me.
Hope to find way to check fuel level from factory sensor via ECU as it accurate.(Tank is divided by two halves and there are two sensors, main and sub and information come from both together)
Thank you in advance.
