EVO X MAP Questions
Hi all!
This is the first time for me working on a Motec ECU, I have to tune a EVO X, I have some questions, does motec provide base maps? As the map I'am using is provided by another tuner and that should be fine for the car but I'd like to use base maps provided from motec if they are avaiable.
Anyway I got the engine started and working, I was able to tune the car so we could check everything was ok but fuel level gauge does not work, and I can't see lambda 1 from motec ecu manager (value stuck at 1,57)
I guess the lambda could be damaged as it is the oem one or misconfigured, but I can't really find a way to make the fuel level work. Can someone help me with this?
thanks
thanks
