m800 plug in, evo 7 wideband
Postby Paulos71 on Fri Apr 21, 2023 10:29 am
Hi guys just bought a m800 plug and play evo 7 ecu. Single Lambda ,logging and advanced features are enabled.Quick question,Want to hook up a Wideband, is it as easy as hooking in a Motec (Bosch)style Wideband sensor into the dump pipe and connecting with evo 7 OEM 02 sensor loom that runs back to the m800? or am I missing something.Silly question but am only a newby to this.
Paulos71
Re: m800 plug in, evo 7 wideband
Postby Stephen Dean on Fri Apr 21, 2023 12:43 pm
Pretty much, you do need to configure the ECU to recognise the lambda sensor being used. I have attached the installation notes for the M800.
DVIN0007 Mitsubishi M800 OEM EVO48 Installation Notes.pdf
(224.16 KiB) Downloaded 921 times
Return to M800 Plug-In ECUs
