Build CAN INTERFACE CABLE
Tue Apr 21, 2009 7:18 am
by Aljiru
Hello¡¡¡
Could i build a CAN INTERFACE CABLE?
Parallel to NEUTRIK connector or Parallel to d9.
Thank
Re: Build CAN INTERFACE CABLE
Tue Apr 21, 2009 1:09 pm
by DarrenR
The Motec CAN cable has quite a bit of circuitry in the parallel connector shell so it is not possible to build one with out this interface circuit board.
Regards,
Fri May 15, 2009 2:37 am
by figgie
aljiru
to add to Darren's post.
CAN is a serial interface with a serial transmission. What you are proposing is basically sending a serial stream into a parallel system that uses parallel data information. Not a simple task of doing that without adding a serial-parallel convertor in the middle and not any serial stream, CANbus.
Look at the older printers that had a serial AND parallel port on it. Not very easy way to go between both.
