Convert from WRX7/8 Plug-In to WRX5/6
Hey there,
I have got a, to my knowledge, M800 Plug-In for WRX7/8 (Product Code: 13003-10074). It came out of a 2002 WRX. I intend to use it on a 1999 Forester GT (WRX5/6) with an adapter ECU header harness.
Apparently, the ECU was locked and couldn't be unlocked, so it got wiped.
Questions:
1. Is it possible to make the adapter harness so that it will connect to the same M800 pins as described in DVIN0009 M800 OEM WRX56 Installation Document.pdf?
2. Would the ECU need a different firmware?
3. I have not powered up the ECU yet. What would it mean if an ECU is wiped?
4. What options are activated on ECU 13003-10074?
Thanks for your help.
Questions:
