13004A & 13007A Startup file
Postby oah on Sat Apr 04, 2009 5:00 am
Dear all :
Are there a way to get the start file for these ecu's:
13004A M800 OEM ECU for WRX/STi V5/6
13007A M800 OEM ECU for EVO8
Regards
oah
oah
Re: 13004A & 13007A Startup file
Postby OmarK on Tue Apr 07, 2009 1:01 pm
When the m800 OEM ECU was purchased, the factory ECU number would have been supplied to us and the appropriate start file already loaded into the ECU. Your local MoTeC dealer may have the start file you are looking for.
OmarK
Postby oah on Wed Apr 08, 2009 5:24 am
I have M800 gold box, I intersting to connect it to these car,and I need these base map to saving time.
Note. I make a connector between goldbox and OEM wiring for sti V.5, and look to make another connector for EVO8, and need the base map to start these engine.
Regards
oah
oah
Return to M800 Plug-In ECUs
