4G63 stock Ref/Sync setup timing accuracy
Given that there is only 2 teeth on the crank trigger wheel there are
2 signal state changes (rising or falling) that ECU can use to sync
its timing what gives resolution of 180 degrees. Or ECU is
using different strategy for its timing?
Isn't it too coarse for high performance engine?
What is recommended crank/cam teeth count for
the high powered engine that can have large RPM changes
in short time period? Obviously the more the better
but there should be some practical limit that won't
improve accuracy much rather then introduce more
possible errors due to some valvetrain slack.
The reason for asking is that I am going to try different
trigger setup on one of the Evos and would like to hear
some opinions.
Regards
Alex
some opinions.
Regards
Alex
