M800 questions
I'm about to buy motec M800 PnP for the Subaru 07 Euro version STi. I'm using stock ecu with ecutek right now but I find that ecutek has limitations because of the MAF sensor. My stock ecu "ID ornumber" is am500-4900. These are my few questions:
1. Will the immobilizer still work with motec? If yes, will the motec ecu recognize my key? Do I need to give my VIN number to the dealer before buying the motec?
2. Will the OBD2 still function so that the subaru diagnostic pc can read the stock sensor etc?
3. Can the motec read the STi's stock sensors like the G sensor, fuel pressure, etc? I just found those info about the stock sensors that the stock ecu can read here
http://www.dashdaq.com/specs/datalists/subaru.htm
4. Can the M800 PnP be used to control NOS and water meth injection system or do I have to use another motec product like the E888 to be able to control it?
Hope to hear from the motec guys here, thanks a lot in advance
James
James
