M800 wrx7 2006 jdm sti base map request
Postby maccakpa on Mon Jun 15, 2020 4:47 pm
Hello guys!
Does anyone have 2005 jdm sti version 9 impreza base map?
the one came with the car got deleted it guess. Its PnP m800 #8114 WRX7 Rev A
maccakpa
Re: M800 wrx7 2006 jdm sti base map request
Postby Stephen Dean on Tue Jun 16, 2020 10:49 am
What is the part number on the OEM ECU case? The base maps are sorted by this so that the correct settings for that vehicle are used, if you can send this through then I can get that file for you.
Postby maccakpa on Tue Jun 16, 2020 9:51 pm
Hello there! Thank you for your reply,
Its
6B
22611AH590
112200-5132
Denso
And it has immobilizer
maccakpa
Postby Stephen Dean on Wed Jun 17, 2020 2:46 pm
Please see attached.
13008A 22611AH591.e23
(24.54 KiB) Downloaded 1295 times
Postby maccakpa on Thu Jun 25, 2020 11:50 am
thank you sir. My rpm does not work? which aux # it should be?
maccakpa
Return to M800 Plug-In ECUs
