Evo 8 M800 CAN communication with MDC
Hello folks, i got last week an evo 8 in the shop, in which i've instaled an PNP M800 and an MDC, I have mapped both and the car is working like a swiss clock. The only problem i have is that i cannot get the MDC to communicate over can with the M800, for logging purposes. The car also has an MDD, over can, which is also working well. Till now, i have tried with both can terminal resistors pads closed and also open, nothing. The same can setup between the MDC and the M800 i have working well, on a previous car. Both group N cars (almost stock). The current car's wiring loom looks kind of...like it went to war, so i have removed the MDC's can connector and connected the MDC with the ecu with a new set of can wires, 10cm long, directly from the mdc to the ecu, still nothing. PS: i can program with no problem both ecu's with the UTC in the same connector.
Kind Regards, Vlad
Kind Regards, Vlad
