Evo 9 plug Inn base map
Postby razzmtazz on Wed Nov 06, 2019 4:28 am
Hi
Guys I have a evo 9/8 plug in have installed it and connected the lap to can't seem to up load any base file which I downloaded form motec site as both versions of the software don't show it on the compatible file please help
razzmtazz
Re: Evo 9 plug Inn base map
Postby Stephen Dean on Wed Nov 06, 2019 9:28 am
The Base maps on the website are ECU Manager V2 files, so they need to be converted first into a V3 file format before you can use them. This is done by opening up ECU Manager and going to File | Convert Old Files... Navigate to the directory that the files are in, and then follow the prompts to convert the files.
Return to M800 Plug-In ECUs
