Datasheet and pinout for 13003 ecu
Postby PQatPIT on Fri Oct 12, 2018 6:56 pm
Possible to get datasheet and pinout for 13003-14272 ecu? What options might be activated?
Thanks! :)
PQatPIT
Re: Datasheet and pinout for 13003 ecu
Postby Stephen Dean on Mon Oct 15, 2018 9:01 am
See attached.
M800 # 14272
Options
28105 : ADV FUNCTIONS
28101 : 1M LOGGING
28112 : DRIVE BY WIRE
28116 : CAM CTRL
DVIN0014 M800 Plug-in to WRX 9-10 Installation Notes.pdf
(694.49 KiB) Downloaded 1567 times
Postby CrisT on Fri Jun 07, 2019 3:06 pm
I don't want to create another thread.
I would kindly like to know what options are activated on 13003-13477.
Thank you!
CrisT
Postby Stephen Dean on Fri Jun 07, 2019 3:33 pm
That M800 has the following enables.
M800 # 13477
Options
28118:OEM ENABLE
28105:ADV FUNC
28101:1M LOGGING
28102:SINGLE LAMBDA
28116:CAM CTRL
Return to M800 Plug-In ECUs
