Evo 9 FBW & ALS
Evo 9 FBW & ALS
Postby broraboy on Thu Mar 08, 2018 3:24 am
Im in the process of fitting Evo 10 FBW to my Evo 9. What ECU inputs do i need to use for this. In addition to this I wish to use variable ALS. Should I just use a pot into an analogue channel or a better way to do it.
broraboy
Re: Evo 9 FBW & ALS
Postby Scott@FP on Thu Mar 08, 2018 6:56 pm
You need aux1 and aux2 for the motor drive, and 4 analog inputs for the pedal and TB sensors.
Re: Evo 9 FBW & ALS
Postby SprinterTRD on Fri Mar 09, 2018 1:21 pm
Are you using a MoTeC EVO89 OEM ECU?
If you are then the EVO89 adapter cannot be used with DBW as it is not designed for this purpose.
You will need a gold box M800 or an M130
Re: Evo 9 FBW & ALS
Postby Fercomp on Fri Sep 14, 2018 8:16 am
Yes its possible to use the DBW with the Evo89 plug in.
Aux out 1 - Drive by Wire Function 5
Aux out 2 - DBW Idle Function 6
Under Functions -> DBW
Prop gain - 120
Integral - 90
Deriv gain - 150
Period - 1
Dead band - 0.3
Feed fwd - 0
Neg clamp - -15
Freq - 8000
Motor V - 14
Comp - 0
Fail safe rpm - 0
Feeback - 0
Fercomp
Re: Evo 9 FBW & ALS
Postby SprinterTRD on Fri Sep 14, 2018 9:37 am
As I stated before, The EVO 89 adapter AUX PCB tracks/circuitry is not designed to drive a DBW motor and should not be used for this.
Re: Evo 9 FBW & ALS
Postby Stephen Dean on Fri Sep 14, 2018 5:12 pm
The Daughter board that is used for the OEM replacement M800 is not designed to cope with the loads required to drive a DBW as the internal tracks are too small. You are also not able to purchase a DBW enable for an OEM M800 if the base vehicle did not come with DBW, this is the same as with Cam Control if the base vehicle didn't have it.
The only way to have DBW with an OEM M800 that doesn't have DBW as standard, such as transplanting a later model engine into an earlier spec vehicle, is by using a DBW4 external controller.
Re: Evo 9 FBW & ALS
Postby Vlad on Fri May 29, 2020 8:27 am
I did have a talk with the tech support team from MoTeC Europe about this, a couple of months ago, i was requested at a service park to check out a datalog on a Evo 8, was running the evo 4-8 PNP and i saw the DBW option enabled...i should have taken a picture to post it...
Vlad Pescaru
Vlad
Re: Evo 9 FBW & ALS
Postby Vlad on Mon Jun 22, 2020 4:46 am
Voila, PNP with dbw enabled
Vlad Pescaru
Vlad
Return to M800 Plug-In ECUs
