Upgrade ECU Mitsubishi Evo-8
Postby super7 on Sun Dec 31, 2017 10:50 pm
Hi.
I help a rally driver with the injection on his
Mitsubishi Evo 5. When I connect the computer to ECU
will this message, so far I have just denied
to upgrade firmware and connect.
What needs to be done at the upgrade?
Serial number of ECU 13003-10173
Mvh Nils-Erik
super7
Re: Upgrade ECU Mitsubishi Evo-8
Postby David Ferguson on Mon Jan 01, 2018 4:49 am
The firmware in the ECU can be upgraded with your version of the ECU manager using the menu Utilities->Upgrade ECU Version...
However, I suggest that you should really first install the ECU manager to match the firmware in the device (you can have several versions of ECU manager installed and use the correct one for a specific ECU. You will find "M400 M600 M800 M880 ECU Manager V3.5L4" on this page: http://www.motec.com.au/software/oldreleases/
Return to M800 Plug-In ECUs
