ALS CAN BUS
ALS CAN BUS
Postby junnan yue on Sat Oct 07, 2017 5:42 pm
Hi everyone
Is there a way to tell M800 PNP ecu to turn on ALS(anti lag) via CAN BUS?
junnan yue
Re: ALS CAN BUS
Postby Scott@FP on Sun Oct 08, 2017 7:28 am
Yes, thru a digital input set up as a switch. Set up switch to use source and channel of the CAN device you are using.
Re: ALS CAN BUS
Postby junnan yue on Fri Oct 13, 2017 2:56 am
Thank you Scott!
junnan yue
Return to M800 Plug-In ECUs
