by Vlad on Fri Sep 15, 2017 10:25 pm
Hy guys, really need help on this, since i-ve checked and rechecked the tune, and found nothing. Engine is a 2.1L 4G64, portend head,valves, solid lifters, magnus mannifold, GTX3583R, ignition projects coils and amplifier and 4-8 M800 PNP. I am experiecing some trouble with spark blow, but that's not the biggest problem. In the log i'm ataching, you can notice the ign advance goin in the timing map value, then, with the TP100%, constant boost and rpm rising, the ign start's to go up like crazy. i have checked all the compensations that are related with the ign timing....and found nothing....the car pushes about 700 crank hp at 2.2bar, E85 tune. Please take a look and give a shot at what it could be with the timng. Knock voltage goes up when the car is missfiring, no real knock in the headphones. Thank you.
- Attachments
20170914-0986806.ldx
- (284 Bytes) Downloaded 1256 times
20170914-0986801.ld
- (177.14 KiB) Downloaded 1230 times
20170914-0986806.ld
- (164.3 KiB) Downloaded 1230 times
Vlad Pescaru
