Incandescent Shift Lamp w/ WRX9-10 Board
Postby mrsaturn7085 on Thu Jun 01, 2017 4:01 am
I wanted to play it safe by asking here first-
I have a Stack ST533 shift lamp (incandescent) drawing 0.6 A when illuminated. It is a simple 2-wire connection with a switched ground.
Can this be directly connected to either INJ8 or AUX8 of the M800 Plug-in (WRX9-10) board, or will a small relay be required? If this can be directly connected, is there a 'better' choice between INJ8 or AUX8?
mrsaturn7085
Re: Incandescent Shift Lamp w/ WRX9-10 Board
Postby David Ferguson on Thu Jun 01, 2017 4:33 am
You can find this information within the ECU Manager. Use the menu Help->Topics. Then click the Specifications->Injector Output Specifications. There you will find that the Injector outputs can sink 2A (4A max).
Aux8 is capable of 1A, with a current limit of 3A.
Return to M800 Plug-In ECUs
