Issue With Some ECU Inputs
Tue Apr 11, 2017 1:40 pm
by raheelfarouk
I have a MoTeC M800 PnP ECU for the Subaru STI 8. I have been having issues with wiring up a switch to control anti lag and launch control. For some reason whatever I try I cannot get the switch to work. I have tried setting it up in the input pins setup screen as well. BTW I connect the switch to the ecu pin and the wire it to the 0V line from the ecu. Can someone tell me what I'm doing wrong
Thanks,
Raheel Farouk
Re: Issue With Some ECU Inputs
Tue Apr 11, 2017 7:48 pm
by Rude Engineering
Which input on the ECU are you trying to use?
Wed Apr 12, 2017 12:49 am
by raheelfarouk
Rude Engineering wrote:Which input on the ECU are you trying to use?
I was trying to use digital input 2(DIG2) and switched input 5/6 (AT 5/6).
Thu Apr 20, 2017 7:49 pm
by Rude Engineering
You shouldn't have any problem using DIG2 (pin A8) or AT6 (pin B12) but AT5 will need to be used on pin A3 with Link 2 joined.
