Subaru wrx9 m800 OEM ECU STart File
Tue Jan 20, 2009 12:12 am
by mhd
Hi every body
How can I get a start file fo OEM m800 ECU for WRX STI V9
Thank's and Best Regards
M.Olabi
Re: Subaru wrx9 m800 OEM ECU STart File
Tue Jan 20, 2009 8:46 am
by RossB
What year is this car, and what engine size (2.0 or 2.5)? Also the original ECU number would help.
Tue Jan 20, 2009 7:27 pm
by mhd
The car 2006 2.5L (strokered to 2.71L) DBW
Thank's
Wed Jan 21, 2009 12:06 pm
by RossB
The attached file is what we install in the M800 Plug-in as a start up file.
Sun Apr 05, 2009 9:15 pm
by mhd
Hi Every Body
Yesterday I start to tune my car but I face 2 problem,
1- I offset the cam table -50 to get the camshaft at 0 ( is that normal ?)
2- Also I add on ignation overall trim 25 degre to make the engine run fine ( is that normal? now at 1000rpm I run 36 degre timming)
3- after some time in tunning 1 and 2 spark pluges stoped working ( is there problem with my tunning setup did this to my spark pluges)
My M800 ECU No. : 10480
Thank's you veru much
Best Regards
M.Olabi
Mon Apr 06, 2009 5:43 am
by oah
dear mhd;
replay for sparks stop working ..... I think there are a problem in your ignition - ref / sync - setup , and you must check the ignition dwell bat. comp.
regards
oah
Mon Apr 06, 2009 10:05 pm
by mhd
Hi
The ref / sync - setup I take it from RossB Start File, and the dwell bat is 2.0 at 14V and 2.5 at 12V
Thank's and best Regards
M.Olabi
