Subaru wrx9 m800 OEM ECU STart File
Postby mhd on Tue Jan 20, 2009 12:12 am
Hi every body
How can I get a start file fo OEM m800 ECU for WRX STI V9
Thank's and Best Regards
M.Olabi
M.Olabi
ProRacing Co.
mhd
Re: Subaru wrx9 m800 OEM ECU STart File
Postby RossB on Tue Jan 20, 2009 8:46 am
What year is this car, and what engine size (2.0 or 2.5)? Also the original ECU number would help.
Postby mhd on Tue Jan 20, 2009 7:27 pm
The car 2006 2.5L (strokered to 2.71L) DBW
Thank's
M.Olabi
ProRacing Co.
mhd
Postby RossB on Wed Jan 21, 2009 12:06 pm
The attached file is what we install in the M800 Plug-in as a start up file.
13012A 22 STI 2006 2007.e35
Subaru start file
(72 KiB) Downloaded 2030 times
Postby mhd on Sun Apr 05, 2009 9:15 pm
Hi Every Body
Yesterday I start to tune my car but I face 2 problem,
1- I offset the cam table -50 to get the camshaft at 0 ( is that normal ?)
2- Also I add on ignation overall trim 25 degre to make the engine run fine ( is that normal? now at 1000rpm I run 36 degre timming)
3- after some time in tunning 1 and 2 spark pluges stoped working ( is there problem with my tunning setup did this to my spark pluges)
My M800 ECU No. : 10480
Thank's you veru much
Best Regards
M.Olabi
M.Olabi
ProRacing Co.
mhd
Postby oah on Mon Apr 06, 2009 5:43 am
dear mhd;
replay for sparks stop working ..... I think there are a problem in your ignition - ref / sync - setup , and you must check the ignition dwell bat. comp.
regards
oah
oah
Postby mhd on Mon Apr 06, 2009 10:05 pm
Hi
The ref / sync - setup I take it from RossB Start File, and the dwell bat is 2.0 at 14V and 2.5 at 12V
Thank's and best Regards
M.Olabi
M.Olabi
ProRacing Co.
mhd
Return to M800 Plug-In ECUs
