WRX9-10 - optimizing cranking for faster start
Could anyone give me a brief primer on how you go about tuning the cranking enrichment to provide a faster start? As it stands, I am using the base map settings and the car (2006 USDM STI 2.5L) starts in about twice the time the OEM ECU can handle the task. MOTEC cranking time is probably 3 sec to start while OEM was 1.5 sec. It's obviously not bad... but I would like to learn how to optimize it.
I assume the best way to do this is just crank (no pun intended) the compensation value up to add more fuel...
Base map settings are attached as image.
