Help me identify this oem board (M48 oem?)
Postby Christian on Wed Jan 07, 2009 8:49 am
I´m being sold an ecu which is said to be a Motec M48 OEM for Evo. I´ve attached few pictures of it. Could anyone help me tell if this is legitimate? Does it have the same features of an gold box M48 besides not controlling 8 injectors? Thanks
m48 01.jpg (38.04 KiB) Viewed 10947 times
m48 02.jpg (49.72 KiB) Viewed 10935 times
Christian
Re: Help me identify this oem board (M48 oem?)
Postby MarkMc on Thu Jan 08, 2009 11:55 am
Hello Christian,
It looks like an EVO M48 OEM (possibly EVO6). The M48 OEMs were literally an M48 without the case or connector and the heat sink was slightly smaller but apart from that there is no difference. All M48s use the same software.
You could use this ECU to run eight injectors (still an M48 remember) but in an EVO the four spare injector outputs were generally used for other functions.
Postby jasaircraft on Wed Mar 31, 2010 7:06 am
what COM cable should be used for this one? (part number please :D )
jasaircraft
Return to M800 Plug-In ECUs
