Fuel pressure sensor
Postby trainwrex on Sun Jan 04, 2009 7:33 pm
Hey guys,
Im running twin intank walbros on my 2004 sti running a motec M800 plug and play.
Would like to put in a fuel pressure sensor so in case fuel pressure dramatically drops then i can get the motec to shut of boost or limit rpm..
Anyway know what i should be getting???
Cheers..
trainwrex
Re: Fuel pressure sensor
Postby RossB on Mon Jan 05, 2009 9:54 am
I would recommend using a Honeywell 100PSI sensor (MoTeC part# 58041). You should be able to wire this in to AV5 or AV6 which are spare inputs.
Postby trainwrex on Mon Jan 05, 2009 11:14 pm
cheers for the reply...
ill have to see if i have spare imputs to use...
trainwrex
Return to M800 Plug-In ECUs
