Evo 9 OEM M800 (GM Delco 3 port BCS)
Hello there,
If I would to install a GM Delco 3 port boost control solenoid to replace the stock solenoid, would I need to install a 10ohms 2 watts resistor, or can I do without?
Noting that the stock boost solenoid has between 29~36ohms resistance and the GM one has 24ohms resistance, thus the 10ohms resistor
Thanks,
Az
Thanks,
Az
