Evo 9 OEM M800 (GM Delco 3 port BCS)
Postby aalzuhair on Tue Dec 23, 2008 12:46 am
Hello there,
If I would to install a GM Delco 3 port boost control solenoid to replace the stock solenoid, would I need to install a 10ohms 2 watts resistor, or can I do without?
Noting that the stock boost solenoid has between 29~36ohms resistance and the GM one has 24ohms resistance, thus the 10ohms resistor
Thanks,
Az
aalzuhair
Re: Evo 9 OEM M800 (GM Delco 3 port BCS)
Postby RossB on Tue Dec 23, 2008 9:04 am
There is no need for the resistor, just set the frequency to 20 Hz and connect it to the same wiring as the original valve.
Return to M800 Plug-In ECUs
