4 inputs for EGT sensors
PostPosted: Fri Aug 14, 2015 11:03 pm
by anasyakoub
I have evo x M800 and I want to connect the 4 EGT sensors via amplifier to plugin M800,
from the pinout manual I found la1 and 2 AT and 1 AV inputs
can I use them ? it will give the same readings ?
Re: 4 inputs for EGT sensors
PostPosted: Mon Aug 17, 2015 10:47 am
by Stephen Dean
Which external amplifier are you using? does it have a CAN output?
PostPosted: Mon Aug 17, 2015 5:42 pm
by anasyakoub
SDean wrote:Which external amplifier are you using? does it have a CAN output?
its from Exhaust Gas Technology, it has Quad Channel Thermocouple Converter 0-5v not can
PostPosted: Tue Aug 18, 2015 4:49 am
by stevieturbo
Maybe this might be of use ?
it says it reads 8 thermocouples and transmits data via CAN
http://www.rrrshop.co.uk/8egt2can---8-t ... -403-p.asp
PostPosted: Tue Aug 18, 2015 4:25 pm
by anasyakoub
stevieturbo wrote:Maybe this might be of use ?
Thanks a lot, I will take a look into this :)
PostPosted: Tue Oct 06, 2015 4:06 pm
by anasyakoub
I have got this device which works fine on its program, but I couldn't get work on M800,
I am using CAN 1 and I have set a custom data set 2, then I have added an EGT graph but it did not work,
do I missed something I have not setup ?
PostPosted: Tue Oct 06, 2015 10:45 pm
by stevieturbo
The two CAN configurations would need to match, but not familiar with how either work.
PostPosted: Sat Oct 10, 2015 4:25 pm
by anasyakoub
Yesterday I have tried to put the CAN data to E888 receive and set up the input pins setup I could read two of four EGT sensors only,
so now the communication between M800 and the EGT amplifier is working, I just want to receive the data
