Hot idle on Evo8 M800 PNP
I have a boring problem with my idle when i drive.
I have an Evo8, with a M800 PNP with AFR option.
Configuration : 2.3 GT35R82, with piper cam 282.
No problem with my cold start, cold idle.
At 90° WT, idle is stabilizing correctly on 1100rpm.
When running, no problem too. But when I slow, or I have to gear down, when the engine has to reachs near that 1100 rpm, the idle falls, and the engine stops. It seems that the idle stepper cannot manage the slow or the gear switch.
Exactly the same when I have to stop, the idle is falling and the engine stops.
The strange thing is that I can drive without this problem, 2-3 minutes, and the problem appears.
Thanks for your help
