Hot idle on Evo8 M800 PNP
Postby gio on Thu Apr 16, 2015 12:24 am
I have a boring problem with my idle when i drive.
I have an Evo8, with a M800 PNP with AFR option.
Configuration : 2.3 GT35R82, with piper cam 282.
No problem with my cold start, cold idle.
At 90° WT, idle is stabilizing correctly on 1100rpm.
When running, no problem too. But when I slow, or I have to gear down, when the engine has to reachs near that 1100 rpm, the idle falls, and the engine stops. It seems that the idle stepper cannot manage the slow or the gear switch.
Exactly the same when I have to stop, the idle is falling and the engine stops.
The strange thing is that I can drive without this problem, 2-3 minutes, and the problem appears.
Thanks for your help
gio
Re: Hot idle on Evo8 M800 PNP
Postby stevieturbo on Thu Apr 16, 2015 7:45 pm
Sounds like it just needs tuned.
Postby gio on Thu Apr 16, 2015 9:08 pm
Unfortunatly, the tune is fine, AFR fine, ignition fine.
Maybe the speed of the idle stepper ?
gio
Postby stevieturbo on Fri Apr 17, 2015 10:49 am
gio wrote:Unfortunatly, the tune is fine, AFR fine, ignition fine.
A "tune" consists of more than 2 tables you know.
Your idle speed control settings are an integral part of that tune. So if there is a problem, then clearly it is not fine.
Postby gio on Sat Apr 18, 2015 7:47 am
Thanks Stevie,
That's the point.
I think I need some help to better understand the meaning of this problem :-)
gio
Postby stevieturbo on Sat Apr 18, 2015 9:45 am
Given the many aspects to get idle nice....it would be very very hard to do remotely unless you were already very familiar with the ecu setup.
And if you were familiar...you'd be able to get to the bottom of the problem already.
Postby gio on Sun Apr 19, 2015 12:29 am
Maybe not enough familiar :-)
I fixed the problem, simply by tuning OV, and add a little bit I.
Thanks.
gio
Return to M800 Plug-In ECUs
