SubarU STI N12 Wideband wiring
Postby bjorgvinben on Sun Jul 13, 2014 1:24 am
I am working on wiring wideband sensor to M800 plug-in on Subaru STI N12
I am wondering if the the original wiring loom and connector are wired to the ECU Wideband controller and can therefore be used.
I have not yet traced the wiring yet.
regards
Björgvin
bjorgvinben
Re: SubarU STI N12 Wideband wiring
Postby mrsaturn7085 on Sat Mar 05, 2016 5:31 am
The WRX9-10 board has a separate connector with loom on the PCB that should correspond w/Lambda 2. If you are using the on-board knock module (OKM), Lambda 1 will be utilized for knock control.
mrsaturn7085
Return to M800 Plug-In ECUs
