M800 data from Mitsu Factory ACD
We have a M800 (Evo9) this is in a race car, no A/C, air bags or any other feature. We are using a "factory" Ralliart ACD control. I am having difficulty with trying to setup sensors from the Ralliart. Is the M800 capable of reading the ACD control in a similar manner as the Motec MCD? Example, I would like to log the steering and each wheel speed from the ACD. according to the MCD documentation, if I setup the steering sensor as ECU2 11 I should be able to read the value of the steering angle sensor. Is this also true for a Factory ACD control?
Link 7 is closed, Link 2,5 are both Open. (this should be the M800 RS232 TX pin, thus it should not affect my issue)
Thoughts?
Thanks, Bryan
Thoughts?
Thanks, Bryan
