Gear shift function
Hello
i'm using the gear shift function to control an air shifter.
There's a bit of a twist though, I'm using a 3d table in aux 4 gear shift up to switch the digital input for gear shift up (ie aux 4 switches dig 3 to ground to activate).
When in utilities i can activate aux 4 and it switches the up shift solenoid perfectly, but no matter what I put in the aux 4 table I can't get the solenoid to operate with ecu connected.
I realise there is a "loop" situation here, but any ideas how to achieve what I'm after? - I want an rpm based, gear dependent table to make the upshift command - ie full auto upshift at the table requested rpm.
Any ideas please?
Any ideas please?
