LA1/LA2 as an AT/AV input
Postby Russ on Sun Feb 03, 2013 3:55 am
On an M800 OEM (Evo 47) is it possible to use LA1 and LA2 as AV/AT inputs?
I've run out of AV and AT inputs and want to fit a DBW throttle, so I'd want to use them as TPS 0-5v inputs.
https://t.me/pump_upp
Russ
Re: LA1/LA2 as an AT/AV input
Postby MileyCyrus on Wed Feb 06, 2013 2:05 pm
Hi Russ,
At least with the regular M800, both the LA1S and LA2S inputs are cabale of acting as a regular AV inputs, so I'm pretty sure you should be fine in using you plug-in with normal AV sensors.
Cheers,
Nathan Tarlinton
Electrical Team Leader
UOW FSAE
MileyCyrus
Postby Russ on Tue Feb 12, 2013 7:53 am
Excellent, thank you Nathan :)
Russ
Postby Scott@FP on Wed Feb 13, 2013 9:15 am
If I remember correctly you have to swap some jumpers on the board.
Return to M800 Plug-In ECUs
