ref/sync problem in evo 8
Hi
I have a problem starting my evo 8 with the m800 plugin ecu. I get the ref/sync syncronised NOT SYNCED error during crank. No other errors just this one. The error doesn't go away even during longer cranking when I press "enter". I know the hall sensors are fine and the wire loom is fine too because the cars starts without a problem on another aftermarket ECU that I have. I did output tests for injectors and ignition outputs. That looks good too. Do you guys know what can be causing the permanent ref/sync error? I took the ref/sync settings from the the base map for evo 8.
