Idle Impreza V8 sti 2003
Postby marcmu on Wed Feb 08, 2012 10:30 pm
my problem is when car is cold i start and idle is in 600-700 rpm and i have to push accelerator a few minutes (if not, i go in road and brake and i have to accelerate to not stop) until engine take some temperature and then remains in 850-900 aprox rpm and car go well. If i try to give more idle, then when car is with more temperature idle will be in more than 1000rpm. Any solution?
marcmu
Re: Idle Impreza V8 sti 2003
Postby Holmz on Wed Feb 08, 2012 11:35 pm
marcmu wrote:my problem is when car is cold i start and idle is in 600-700 rpm and i have to push accelerator a few minutes (if not, i go in road and brake and i have to accelerate to not stop) until engine take some temperature and then remains in 850-900 aprox rpm and car go well. If i try to give more idle, then when car is with more temperature idle will be in more than 1000rpm. Any solution?
On this page
http://www.motec.com.au/webinars/webinararchive/
You will find this link:
http://motec.na5.acrobat.com/p40634530/
It may be helpful as a start.
Return to M800 Plug-In ECUs
