crank/sync errors
PostPosted: Sun Jun 12, 2011 1:54 am
by stevieturbo
M800 pnp Subaru 2002 STI
Pretty much every time the engine is revved hard we get these errors.
ref and sync, and runt error. Car appears to run fine despite these.
Is this just a filtering issue, voltage level ? clearly it is something that needs rectified ?
Re: crank/sync errors
PostPosted: Sun Jun 12, 2011 2:58 am
by stevesingo
Steve,
I had a similar issue and spoke to Motec UK. The Runt error is a voltage being seen on the sensor signal that is below the filter level and therefore does not effect the true signal.
I did a ref/sync capture to try to identify the rouge signal, but nothing showed up on the scope.
HTH
Steve
PostPosted: Sun Jun 12, 2011 8:51 am
by stevieturbo
I understand teh runt error is something that can be overlooked. But it is also coming up with ref/sync errors
Crank trigger and sensor etc are all factory,
Mind you, it also throws up injector 2 open error for some obscure reason at times,
PostPosted: Wed Jul 06, 2011 10:40 am
by MarkMc
If it is not causing an issue I would not worry about it too much. I assume from logging the errors happen at around 6-7000rpm? Which ref/sync errors exactly?
