by mariosandreou on Mon Sep 22, 2008 8:56 pm
i want to know the main setup for fuel and ignition for sti spec 2004 std turbo and injectors.
m800 is the ecu .
mariosandreou
by RossB on Tue Sep 23, 2008 9:43 am
I have attached an M800 start file for a 2002 STI which should contain all the settings you need. This is the file we send out with the ECU so it is a start up file only.
- Attachments
13008A 22611AH190.e23
- (24.54 KiB) Downloaded 1404 times
Return to M800 Plug-In ECUs
