intake air temp. and MAP sensor scaling - Evo 9 GT
Postby Yaro on Fri Apr 15, 2011 8:00 am
Guys, could you help me. I fitted Motec Ecu into my evo 9 GT and I want to use stock intake temperature sensor and 3 bar JDM stock map sensor(I suppose they are similar to 9rs model and they are both fitted onto intake manifold) . The problems is I dont know the voltage/temperature scaling for IAT and voltage/pressure for MAP sensor. Could someone tell me this scaling ?
Yaro
Return to M800 Plug-In ECUs
