Evo 9 boost control
Evo 9 boost control
Postby jurgen on Wed Sep 17, 2008 6:02 am
I have problems by setting up a PID boost control on an evo9. car doesnt make more boost dan 1.6 bar. wich jet do i have to yuse and what pid corrections??? anyone a base map for that??
jurgen
Re: Evo 9 boost control
Postby Mazi on Wed Sep 17, 2008 8:42 am
If you have two boost control solenoids jet should be 0.9 or 1.0mm bore and 7mm long. With single solenoid 1.2 mm.
With two solenoids you have to check if pins 41 and 63 are linked together. Try to run ign3 output test (DO NOT FORGET TO DISCONNECT IGNITION COILS FIRST!) and try to find out which solenoid is making sound. If both boost control solenoids are disconnected there must be no sound around engine during ign3 output test. Sometimes........ ;)
Are you running v3.4x firmware or previous version?
MAP or MAF controlled?
Mazi
Postby jurgen on Sat Sep 20, 2008 8:13 am
I'm running 3.4 software with map
jurgen
Postby Mazi on Sat Sep 20, 2008 9:50 pm
Jurgen
Send me your email address on PM.
Mazi
Return to M800 Plug-In ECUs
