Fanissues
I have a strange problem.
I hardwired a fan for the FMIC into the Motec M800 on EVO9
1) 12V connection
2) Ground connection
So the fan starts when I put the ignition on.
If I start and run the car it works fine.
Then I disconnect the 12V cable (from the fan) at the ECU's side (cut it)
the car starts but runs on 3cyls, it stalls after +-5seconds and bangs and pops.
I then connect the 12V cable again (from the fan)
and it runs perfect again.
what is wrong here??
maybe different issue maybe related.
I also put an AEM 5 bar map sensor in the inlet manifold
and this occasionally reads totally wrong when tyring to startup the car.
also misfires.
But this is sometimes ok sometimes not.
If not related then I'll take it out of the manifold and put it inside the car
to protect it against heat/vibration.
1) 12V connection
also misfires.
