Fanissues
Fanissues
Postby Eric on Mon May 31, 2010 6:08 pm
I have a strange problem.
I hardwired a fan for the FMIC into the Motec M800 on EVO9
1) 12V connection
2) Ground connection
So the fan starts when I put the ignition on.
If I start and run the car it works fine.
Then I disconnect the 12V cable (from the fan) at the ECU's side (cut it)
the car starts but runs on 3cyls, it stalls after +-5seconds and bangs and pops.
I then connect the 12V cable again (from the fan)
and it runs perfect again.
what is wrong here??
maybe different issue maybe related.
I also put an AEM 5 bar map sensor in the inlet manifold
and this occasionally reads totally wrong when tyring to startup the car.
also misfires.
But this is sometimes ok sometimes not.
If not related then I'll take it out of the manifold and put it inside the car
to protect it against heat/vibration.
Eric
Re: Fanissues
Postby IJ. on Mon May 31, 2010 10:47 pm
So you're not running any sort of relay and have the fan wired direct to the M800?
IJ.
Re: Fanissues
Postby Eric on Tue Jun 01, 2010 11:30 pm
Yes, that's correct.
Fan is a slimline fan and only needs 12V and ground.
So I wired the ground to the ground connection of the ECU
and 12v to a 12v plug on the ECU (on that 12V plug there are other sensors connected aswell)
No relay as this is a racecar and the fan can blow all the time, not an issue.
Eric
Re: Fanissues
Postby Karel on Wed Jun 02, 2010 3:58 am
And what about amperage ? My fan will blow the Motec easly without relay...... is your so weak ?
Karel
Re: Fanissues
Postby IJ. on Wed Jun 02, 2010 10:00 am
Eric wrote:Yes, that's correct.
Do you know the Current demand of the Fan and the Supply at the AUX on the M800 you're using?
IJ.
Re: Fanissues
Postby stevieturbo on Sat Jul 03, 2010 4:33 am
No aspect of a cooling fan should ever be wired directly to the Motec, or indeed any ecu.
Either your explanation of wiring is unclear, or you have it wired very wrong.
If you want it to simply run all the time, wire it either to the main ignition switch and battery ground, or directly to the battery.
Obviously with suitable wiring and fuses.
Although I suspect, and hope that you havent actually wired the fan directly to any of the Motec's outputs. As there is a good chance of damage due to overloading circuits if you did.
Return to M800 Plug-In ECUs
