My evo 8 with 3 bar map sensor ( think bosch sensor), currently set up as 15# kpa delco 300kpa it appears to be reading quite high, on full load when the car is boosting 1.8 bar ( taken from greddy BC) the ecu shows that car is boosting at 2.1 bar which i think is wrong . Any ideas please? is it possible that my sensor is gone faulty?
Also the previous owner had set up the BAP channel to run of the map sensor, both channels were using the same output?? is this normal?? i just changed the bap channel to use oem BAP sensor which is now reading as it should
thanks in advance
