Need Help car not running right after ecu update
I recently update to v35 in my evo 8 as i needed some features that v23 didnt offer, but the only reason i was using v23 beacuse i was well used to it.
I converted the files, and checked everything as instructed.
the car starts fine but it idles very rough and it can hold the steady idle, and if i tip the throttle car revs around 2k rpm and it wont settle??
I wonder if thats something to do with new tables Injector battery comp, and injector scaling?
Im running sard 1000cc injectors,
Does motec have any suitable tables for these injectors please? i only found listings for delco and bosch injectors in motec Help section?
thanks a lot
thanks a lot
