SUBARU N14 PROBLEM
Tue Mar 30, 2010 2:57 am
by dragcar2007
Did anyone ever had an issue on the latest subaru sti (2008) regarding clutch switch fuction?M800 pnp installed car started but every time clutch is pressed starter motor comes in even the engine is running.
Any suggestions???
Re: SUBARU N14 PROBLEM
Wed May 26, 2010 7:59 pm
by Karel
I am running M800 on custommers N14, but no issue. It must be some wiring problem. Ecu does not send signal to the starter, just you with the keyswitch.... or not ?
Mon Jul 05, 2010 6:26 am
by dragcar2007
That model is the one that subaru offers with some extras and it has no key switch but a controller and starter is engaged when pressing the clutch.Have you managed to run the m800 and having the abs working ok?
